MadMaxx
Will a vac leak (small) throw a "check engine" light code? The car is running fine it seems, but the SES light came on and stays lit when I fired the car up a few days ago. I've checked all the sensor plugs and they seem to be all plugged in a working. I did loose one of the manifold "caps" that plug the vac lines, and the PCV gromet on the valve cover. Enough to throw a code?
I don't know if it's related or not, but there is the slight "tink" when the engine is shut off after bringing it up to operation temp, near the back of the engine. It's the sound of metal expanding and contracting.. normal? Should be fine, i've just never listed to the motor that close when it's been shut down I'm just being paranoid LOL
One other minor thing... the throttle seems "loose" to me, even after re-adjusting the ratchet mech on the cables. Any ideas?
MM
96 Viper RT/10 Twin Turbo project
MM
