Hi Dave,
The diagram above is for a Gen1 with two PCM's.
Assuming you have only the VEC1 and not the LED display, you need to run the black wire to ground and the red wire to a keyed power wire that stays hot in start (I use a 14 gauge blue wire that's directly under the steering column in a bundle with other wires).
The two remaining wires get run into the engine compartment. Instead of going to the PCM, you can run them toward the MAP sensor on the intake manifold, at the rear corner of the driver side.
Cut the middle MAP sensor wire, which is green with a red stripe. Connect the green wire from the VEC1 to the end closest to the MAP sensor and the purple wire to the remaining end going to the PCM.
Start the engine and make sure you have no check engine light.
Dial the low to +10 and the high to -16. Rev it up and let it come back to idle while adjusting.
Regards,
Sean
