Viper Registry
ViperJeff
Legacy Member
Idaho
Viper Truck Registry/Viper Registry
Phase 6 Complete
Phase 1: Discover All Viper Truck VIN's
Phase 2: Discover All Viper VIN's
Phase 3: Document All Viper Equipment Lists per VIN
Phase 4: Viper Equipment Breakouts
Phase 5: Document Viper breakouts on Registry Web Page
Phase 6: Document All Viper Truck Equipment Lists per VIN
Phase 7: Viper Truck Equipment Breakouts (in Work)
Not started
Phase 8: Document Viper Truck breakouts on Registry Web Page
Phase 9:Verify All Years 1992-2017 Viper and Viper Truck are complete on Web Site (Currently some Viper data is missing)
Phase 10: Bring the IVR Current
The IVR I have not updated for some time. A lot of things I needed to complete before I did that and the format that was used in the beginning got very awkward with GEN IV & V with all the different options. Trying to decide if returning the IVR 1992-2008 the way that Jay Herbert let it and adding GEN IV & V to a different page that allows for the carious combinations without squeezing things down so much that they can actual be read. A lot to consider.
Getting there
At some point I was going to place everything in an ebook(s), until I started reading about ebooks. It seems the biggest issue with ebooks is Piracy. There is an estimated 30% loss due to illegal copies. Also seems that there are some pretty easy work around's to the protections that can be put on ebooks. The thought was to do a year by year breakdown, VIN, with the Equipment List and several breakdowns.
The safest way would be paper. A little research there was a bit horrifying. Something as simple as the 1992 Viper would be (my cost) between $9-11.00 per copy as the book would be between 300-350 pages. That was with A5 size paper, print would be pretty small. Decided not to look any further as a full 8.5x11 paper would probably be near $20.00 a book (just a guess) and with the 2005 Viper Truck being over 5000 trucks would possibly mean the cost (to me) would be greater than $150.00+ a copy. That is not a good deal at all, 19 bucks maybe.......
So until I figure out a better e solution. I should be done this year with all the documenting
Yea!!!
Vj
V
ViperJeff
Legacy Member
Idaho
Viper Registry Update
As some know, on 10/01/2020 a large portion of the Viper Registry was closed and I no longer Register Vipers into the database. On 10/01/2021 I will be closing another portion of the Registry. I no longer will be providing Build data to include build numbers where I have them, on a regular basis. I might work on those request once a quarter to twice a year. I've kinda moved on to another hobby and there isn't much time for this one.
Humbly
Vj
V
ViperJeff
Legacy Member
Idaho
Update: as I continue to close various aspects of the Registry, the work continues in making public what I’ve learned over the past 18 years.
There is the ongoing work on the Books. Pure data, no story www.vipertruckregistry.com
The forum, www.ViperRegistry.com that will in time document every Viper and Viper Truck
There is no timeline as I work on them in my free time, everything but the books is still free
V
ViperJeff
Legacy Member
Idaho
Small changes to the way data will be presented on the www.viperregistry.com. I will not be going back to update previously entered ones until there is a change or requested. With that said, just like the Books, the build info that I have will now be included. Sadly, I do NOT have 100% of that data as that effort ended earlier this year.
Dodge Viper
2017 DODGE VIPER SRT GTC COUPE TWO DOOR COUPE
Details
{UnRegistered}
Special Edition: Vooodoo II Edition 13/31
Build Number: #726 of 841
Color Build #: #125 of 145
RT/10 Build #: # of
GTS Build #: # of
ACR Build #: #503 of 594
SRT Build #: # of
GTC Build #: #502 of 582
6/16/2017 10:00:00 AM
Venom Black Clear Coat
Mileage:
VIN: 1C3BDEDZ7HV500582
Pictures
Equipment Listing
VIN 1C3BDEDZ7HV500582
Vehicle Description 2017 DODGE VIPER SRT GTC COUPE
STANDARD EQUIPMENT
Monotone Paint
180 Amp Alternator
600 Amp Maintenance Free Battery
Battery Run Down Protection
Electronic Stability Control
5 Mode Electronic Stability Control
Alcantara Trimmed Interior
Cup Holder Insert
Child Seat Upper Tether Anchorage
D/P Seat Belts w/Preten & L Limiters
Advanced Multistage Front Air Bags
Premium Cloth Headliner
Side Front Door Air Bags
Floor Carpet
Cargo Compartment Carpet
Trunk Dress-Up
Pass Grab Handle - L w/ SC Stitching
Pass Grab Handle - L w/B Stitching
SRT Leather Shift ****
PB Handle - Leather / B Stitching
3.55 Rear Axle Ratio
Limited Slip Differential & Rr Axle
NVH Enhancements
Tinted Windshield Glass
Front Door Tinted Glass
Rear Window Defroster
Driver Side Sun Visor
Rear View Auto Dim Mirror
Passenger Side Sun Visor with Mirror
Power Mirrors
Remote Proximity Keyless Entry
Keyless Entry w/Immobilizer
Keyless Enter and Go / Passive Entry
Air Conditioning w/Auto Temp Control
Hood Insulation
Instrument Cluster w/Display Screen
SRT Performance Pages System
220 MPH Primary Speedometer
Fuel/Oil Press/Volt/Coolant Gauges
Tachometer
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locking Glove Box
Remote Fuel Door Release
Inside Emergency Trunk Lid Release
Active Noise Control System
Black Shift Bezel
Key Fob Trunklid Release
Speed Sensitive Power Locks
Pwr Front Windows, 1-Touch,Up & Down
Warning Chime
Headlamps On Warning Chimes
Shift Indicator Warning Lamp
Message Center
Front Passenger Seat Belt Alert
LED Taillamps
Vehicle Information Center
Front Reading/Map Lamps
Automatic Headlamps
HID Headlamps - Semi-Gloss Black
Premium Security Alarm
Gloss Black Rear Applique
Front License Plate Bracket
GTS Front/Rear Fascias
Viper Door Sill Plate Applique
Dual Side Sport Exhaust
16 Gallon Fuel Tank
Engine Oil Cooler
Cruise Control - w/ SW Controls
Electronic Launch Control System
Uconnect 3C NAV with 8.4" Display
SRT High Perf Audio, 12 Speakers
900 Watt Amplifier
Integrated Window Antenna
Steering Wheel Mounted Audio Ctrls
Power Rack and Pinion Steering
Tilt Steering Column
No Spare Tire
ParkView Rear Back-up Camera
Power Adjustable Pedals
Sport Pedals
Tire Service Kit
Universal Garage Door Opener
Tire Pressure Monitoring Display
Structural X-Brace
Capless Fuel Fill w/o Discriminator
English/USA Language
SRT Track Experience
Brake Calipers - Red
O/B Refueling Vapor Rec Fuel Syst
Body Panel Parts Module
Instrument Panel Parts Module
Tire & Wheel Parts Module
Build To U.S. Mkt. Specifications
GVW/Payload Rating
U.S. Dealer Retail
Zone 63-Dallas
ZD/5771 Vehicle Family
2017 Vehicle Specifications
Price Class S
Two Door
Vehicle Order Tracking
U.S. Specifications Label
Texas Ship to State Code
Texas Sold to State Code
OPTIONAL EQUIPMENT
High Grip Alcantara Leather Seat
Black
ACR Interior Package
ACR Package
Vooodoo II Edition
Extreme Aero Package
Carbon Ceramic Matrix Brakes
ACR Door Trim Panel
All Seats with Leather Trim
ACR Floor Mats
ACR Console
Custom Car Cover
6-Speed TR6060 Manual Transmission
Finned Differential Cooler
8.4L V10 SFI Engine
ACR Instrument Panel
GPS Navigation
GPS Antenna Input
Manual 6-Way Driver/Passenger Seats
Lower Dive Planes
Vooodoo II Driver Stripe w/Tracer
Extreme Wing Spoiler - Exposed Weave
Extreme Front Splitter
Carbon Fiber Belly Pan
Upper Dive Planes
Extreme Hood
Extreme Rear Diffuser
Vooodoo II Sill Decal
Satin Black Front Decal
50 State Emissions
All Radio Equipped Vehicles
HD Radio
8.4" Touchscreen Display
Harman Radio Manufacturer
SiriusXM Satellite Radio
Media Hub (SD, USB, Aux)
SiriusXM Travel Link
SiriusXM Traffic
Remote USB Port
Uconnect Access
All VP4 Radios
Alcantara Wrapped Steering Wheel
Manually Adjustable Suspension
P295/25ZR19 P355/30ZR19 ACR Tires
Kumho Brand Tires
All Aluminum Wheels
19X11.0 19X13.0 ACR Gloss Black Whls
Satin Black Fuel Filler Door
Integrated Voice Command w/Bluetooth
Vooodoo II Serialized I/P Badge
SiriusXM Radio Service
For Details, Visit DriveUconnect.com
For More Info, Call 800-643-2112
1 Yr. Trial (Registration Required)
5-Year SiriusXM Traffic Service
5-Year SiriusXM Travel Link Service
5 Additional Gallons of Gas
FAM: ZD TRACKING: 70119L09 MY:2017
Customer Preferred Package 2DK
Customer Preferred Package 22K
Gas Guzzler Tax
Schedule D To C Tracking
Sold Vehicle
United States Region Group
NAFTA Region
V
ViperJeff
Legacy Member
Idaho
Now that 2022 is here, the next phase will be underway. As most know, I've stopped actively collecting data, the Registering of Vipers is no longer active, however, I still add them as people send them in. Registry Certificates have ended, Dash plaques have ended.
So what is the "New" Phase?
Along with the Books, I will start build FAQ Sheets that do breakdowns by Color, Stripe, Interior, Wheel and a few others based on the Year/Model.
These may not cover all Years/Models because there's not enough of a difference to do the FAQ Sheets.
This is where it may get interesting, my FAQ Sheets will be based on Factory data that I have collected and NOT post factory upgrades, modifications and additions by dealers, painters, non-factory promotional Vipers, and the list goes on. I do have "some" post factory details that "may" make it in the FAQ Sheets.
I have not started any of these, but I have individually done them for years as people ask. The idea is to have the breakdowns built and ready all the time. Will it meet everyone's needs, oh **** no! Will it even be valuable for everyone, nope. However, I feel that some may find some use in them. I haven't decided where I will house them or if they will be a document or a web page, I'll decide that after I get them formatted and ready.
It's going to be a busy year
V
ViperJeff
Legacy Member
Idaho
GT Breakout Request
I have two data points that I've been able to use from the equipment listing, "Bright Chrome Viper GT Sill Badge" (2015,2016,2017) and "GT Badge" (2015), no equipment list showed both
2015 151 "GT Badge"
2015 1 "Bright Chrome Viper GT Sill Badge"
2016 54 "Bright Chrome Viper GT Sill Badge"
2017 122 "Bright Chrome Viper GT Sill Badge"
328 Total
jpolen21
