Viper Specific Fluidyne Radiators - $700.00 Plus Shipping
L
Larry Macedo
Sanford, FL
Danny,
I'll be better able to give you that information in a few weeks since I have a car coming in next week for the Paxton Tuner Kit. Since I'll be installing my own front mount I'll be upgarding the radiator as well.
Qualitywires.com
Louisville, KY
I think you will have a hard time making it fit due to the elbow of the filter. You would have to get rid of the filter and put a "mushroom" type one on?
Mike Adams
guelph, Ontario, Canada
The rad will fit with the paxton. The only concern is that the upper rad hose comes out the same spot. I know that BE COOL rad fits fine I would assume the Fluidyne is the same.
LTHL VPR
In case you are wondering.....yes the Paxton kit will work with the Fluidyne. It takes a bid of modification/fabrication, but the end result is much better and more effective than the initial setup. I actually routed the air filter in the fascia around where the fog light openings are. The air here is MUCH COOLER than the air under the hood which is where the standard Paxton setup lies. Well worth it!!
Callaghen
