want to switch from run flats!!
ViperWally
Clarksville TN
I would like to switch from run flats. I have an 03 SRT, what does everyone recommend? I dont track the car, would I need to get new TPS sensors?
I guess what im asking is what would I need to swap from run flats to non run flats, and what does everyone recommend?
Thanks :D
SSGNRDZ_28
Indianapolis
You can keep your existing wheels / sensors. Not sure if it is worth changing sensors while you have the tires off due to battery life? I heard someone say they can last 7 years+. New sensors will require the serial numbers to be programmed into the system so it is a bit more involved.
One good tire option is the Michelin Pilot Super Sports, I recently put a pair on and they work well.
RolandDV
Antwerp
3rd the Michelin. I had the Original runflats still on the car from 2006. Lastmonth I changed to the michelin Super Sport. What a difference. The car now realy sticks to the road and handles much better.
Roland
swexlin
West Chester, PA
Thanks :D
Michelin PS2s, which have now been superceded by the Super Sport. What 99.99% of us use.
I switched to the PS2 when I bought my car 3 years ago, and when they need replacing, will use the Super Sport. The runflats were dangerous when new. I saw an 04 at show on Saturday, which the original ZPs. Only 3000 miles on the car, but they are still 10 year old tires. She wouldn't listen to me...
Likewise, we recommend the Michelin Super Sport as one of the great alternatives to the run flat. We offer them for a pretty good price, free shipping inside the US included:
https://www.viperpartsofamerica.com...t-set-for-2003-2010-viper-275-35-18-345-30-19
Another good tire that many use is the Nitto Invo, also available in Viper sizes:
https://www.viperpartsofamerica.com/index.php/products/nitto-invo-full-set-2003-2010
Just remember that you will want a compressor/sealant kit just in case you get a flat. This is the one that shipped with all newer Vipers (non-runflats):
https://www.viperpartsofamerica.com...ge-viper-srt10-tire-air-compressor-68082668aa
https://www.viperpartsofamerica.com...010-dodge-viper-srt10-tire-sealant-68082669aa
Hope this helps!
viperprowler1
SW FL
Fourth on the Super Sports. I bought mine from VPA last summer and it changed the car dramatically. VPA's price was awesome as well.
Roland
PeterMJ
Thanks :D
If you still have the run flats, you should swap them to currently offered tires due to age. If the tpms sensors are the original ones, you should change them as well because their batteries are past their anticipated lifespan.
CaptainDavid
Duluth, Georgia
By all means shed the run flats, they are dangerous, especially with any age on them. They are hard and react badly to cool weather. replacements are commonly Michelin PS'2's or the Michelin super sports. The Viper you save might be yours....
Allan
La Junta Colorado 81050
The Super Sports are probably the best tire currently available for the Viper. -for street/all around use.
...I haven't tried them yet though.
I have previously been through a few sets of Nitto Invos.
These are great for the street/highway. If cost is any consideration, I think the Invo is unbeatable.
F
FrgMstr
Guest
Have had on Kumhos, Nittos, and the MSS. Already got another set of MSS in the garage. They are awesome in corners, straights, rain, you name it....
ViperWally
Clarksville TN
thanks guys, I guess Super Sport it is. Im not sure if the sensors have been replaced or not Ill look through the receipts to see what the previous owner did. this was very helpful.
ViperWally
Clarksville TN
Hope this helps!
Thanks VPA Ill get on your websight and look around. :)
PeterMJ
I would check this part for sure, the sensors have batteries in them, would be a bit long. I believe vpa also sells the sensors that can be preprogrammed to match your car, without a need to go to the dealer to have them reset. All you have to do is have the dealer download the current sensor codes and they can be duplicated on the new ones. At least I think it was vpa that offered this service.
SSGNRDZ_28
Indianapolis
I know this service is offered by Viper Specialty, not sure about VPA.
http://viperspecialtyperformance.com/catalog/product_info.php?products_id=154
SSGNRDZ_28
Indianapolis
Cost is per sensor AFAIK.
You can read the codes off of the sensor once the tires are dismounted if you have time to wait on the new sensors otherwise you would have to get the dealer or someone else with a tool to read the codes.
Qdog
