Water Pump Issues
viperjim
Maryland
My 2003 has been slowly weeping water from the weep hole on the water pump. Last night it started to overheat. I ended up adding 1.5 gallons of antifreeze after it had cooled down 10 minutes later.
Has anyone else lost their water pump?
Viper X
First one I've heard of.
How many miles on your engine?
Cape Coral, FL
Ditto, first one I have heard of actually going bad.
Not expensive, simple swap. Remove air cleaner and belt, remove the pump bolts, change pump, reinstall bolts @ 100 in-lbs, reinstall belt and air cleaner, top off coolant with 50/50 mix of Mopar Orange 5-Year and Distilled Water.
V
viperjim
Maryland
12,000 miles. When the car was on a lift two weeks ago we noticed a little coolant on the undercarriage.
Viper X
I have 38,000 miles on mine with no issues.
knuk
You should have a powertrain warranty on the 03 and I believe the water pump is covered.
