What is the easiest way to access the fuel tank in the back?
Qualitywires.com
Louisville, KY
I need to get at the top of the fuel tank. I can probably figure it out, but wasn't sure if any of you guys a had any tips before I do it.
Pictures would be awesome also!
Tom Sessions
Hampstead,NC.
Adam,there is a access panel i the center of the rear deck.You reach it by pulling the carpet back on the deck right behind the seats and you will find a plate with 4 rivets holding it i place.this will give you access to remove the fuel pump module.
luc
Paso Robles CA
My understanding is that the access panel is only for the R/T.
On the GTS you need to CUT a opening to get to it .
Luc.00GTS
Tom Sessions
Hampstead,NC.
The RT has a panel to remove the fuel tank.If you need to take the tank out of a GTS then you need to cut out the panel to remove.You don't need to take the tank out of a GTS to remove the fuel pump but you do on a RT/10.
tbone96
