What's the easiet way to install this metal brace...
97snk
I know it was a pain to get off, what's the easiest way to put this back on? I m sure there's a trick to it...
snakebitdave
Mi, USA
Jack the car up so that the front wheels are off the ground and the distance between the wheel wells will open up enought to get the brace out or in.
RTTTTed
Plum's right. Paxton doesn't use the crossmember. My Paxton car has a custom built tube Xmember with Heim ends for support adjustment. Not sure if this is part of the Paxton kit - Phil?
97snk
I thought you had a paxton. If you do....it doesn't go on I believe.
I was planning on putting the head/cam setup together, running the car for a few weeks to make sure everything works and than do the paxton install, this way if I left anything out on the head/cam setup would be worked out before the paxton install :dunno:
ViperTony
When I removed/installed this cross member I jacked up the front of the Viper from the center frame member. This relieved pressure on either side of the brace which allowed me to slip it off and slip it back on. I did have to use a rubber mallet to help coax it back in a bit but went in without issue. Once I had it installed and aligned with the bolt holes, I installed the bolts, tightened them. I then put the Viper back down on the ground and finished torquing the bolts for the cross member.
plumcrazy
ALL OVER
you might wanna install the paxton bar so you dont have to do it later. but i think it is easy (on top of the motor) so it wont be an issue.
half the motor comes apart to the paxton anyways...LOL
97snk
I really can't decide if I want to run the car before installing the paxton or just installing the paxton and towing it off to DC performance for tuning. I m sure they will be able to fix anything that I missed with the build...what do you guys suggest?
RTTTTed
I do all of my own work after buying my cars. I am not the greatest at tuning and will eventually go to a Pro tuner (like DC Perf) once I'm finished.
The Paxton should come with a rough tune and the tune shouldn't matter until about 3,000rpm so you could drive it to DC Performance gently, and at low rpms - after you get it put together unless you're a long ways away. If the car doesn't run well enough then you have the tow option.
If you're not comfortable with it then tow it to DC Perf. They have a stellar reputation and will do a good job.
Ted
Jack B
NE Ohio
Ted
IMHO - you want to run the car with the new heads/cam prior to complicating (the sc) the equation. This way you can get a base line dyno pull before you add the sc. Then there is no finger pointing if the hp is not where you want it. What are you using for engine management?
Jack B
NE Ohio
Ted
IMHO - you want to run the car with the new heads/cam prior to complicating ( sc) the equation. This way you can get a base line dyno pull before you add the sc. Then there is no finger pointing if the hp is not where you want it. What are you using for engine management?
97snk
I do have the split second but I might just do a SCT tune...but it's going to be between the two...which ever is more reliable....:dunno:
Jack B
NE Ohio
You won't be able to change the closed loop fuel map with the split second, therefore, you will lose some drive-ability. Good luck with the build.
plumcrazy
ALL OVER
im the first to admit i have NO clue about tuning. but i know for fact, my driveability is spot on with the split second.
potterb4
