What's wrong in this undercarriage picture?
Lawrenzo
Colorado Springs
This is a 1999 GTS that I am considering, and I just wanted some extra eyes on this undercarriage shot. The area of my concern is where the cross-member hooks up to the frame. What's going on in this picture? Is it simply corrosion or some form of damage/repair? Also, are the bolts on the bottom right the correct type? They seem to be of two different materials.
Uploaded with ImageShack.us
Fatboy 18
Surrey, United Kingdom
OK the bolts holding the rear bumper look the same as mine but Im not sure whats going on where the cross member meets the frame? It could be corrosion or a bad weld but the photo is not that clear? Sorry. Have you personally inspected the car up close, or are these pictures someone sent you? That's also an after market exhaust.
CEJ
Raleigh, NC
Almost looks like something is out of kilter in that photo. The odd angle doesn't help. If that is only mud, how'd it get there in the first place?
Vipuronr
Would definitely ask for closeup shots of both sides, as Plum mentioned. If you are not seeing the car in person, a must is to have someone inspect the car. Nice stainless exhaust! My only issue with it being mud rather than something like surface rust, is that there isn't any other spot with the same "stuff" on it.:dunno:
That said, the left side does look more like rust.
DrumrBoy
GA
Parts look right.....rust or mud. If its mud, shame on the owner for not cleaning it off before taking the pic, sliding backwards in the grass or dirt would put mud there. Hard to tell but my bet would be mud.
If its rust, then there's been some bad welding done there....the pieces are all 90 degrees and the welds are very small.....if thats a weld it either is because a piece has been put in at a non-90 degree angle or the weld was done by a blind first-timer.
Either way, it doesn't seem like a big deal - except aesthetically.
LifeIsGood
Viper Lane, Arizona
Your picture is too blurry to tell...as a reference...here is what my 2001 looks like down there (has a Corsa exhaust)...
DrumrBoy
GA
Wow, very very clean LifeIsGood. On second inspection, it seems like there is also mud-like stuff in a bunch of places (to the right of the center hanger, above the hangers just ahead of the heat shield, etc)
v10enomous
NW Jersey
There seems to be something round above the outer end of that little cross support just above the mud or rust.
Green Viper
Washington State
This one would require a closer inspection, if you look at the absolutely great picture of a well maintained car by "life is good" it appears the angle of the part on the right on the blue car is off a little. While it is hard to tell for sure since one if straight and one picture off angle, it does appear that the two sides are different as well, worth at least a follow up question and a carfax report, IMO.
Also agree with the comment about the color, Blue cars on Gen2s were only produced in 96-97, not 99, so that would lead to more questions.
A couple of features that would help determine year, power mirrors, air bag switch, remote trunk release. It would have all if it was a 99.
Lawrenzo
Lawrenzo
Colorado Springs
Definitely a '99- It's Silver with blue stripes. The owner advertises it as "Pristine", but after seeing Lifeisgood's pictures, I'd say "good" at best. Getting clear pictures from the owner has been difficult, so the only way I'm going to get a better understanding of what's going on with this car is with a plane trip.
I'm curious about that round piece sticking up on the passenger side as well. Could it simply be a difference from a '99 to an '01?
The engine bay looks clean-
Joe Dozzo
Golden, CO
Deleted by poster... Wrong / bad info
v10enomous
NW Jersey
Just checked. No round things on my 98. I suspect it's been curbed hard. The surface of the control arm looks much newer and is not consistent with the rest of the underside of the car.
CEJ
Raleigh, NC
"Pristine"? Maybe the seller needs to look up that word in a dictionary.
Check out the brake reservoir...dark fluid is not a good sign, unless he used that blue stuff. Makes me wonder when the coolant was last changed too.
There are better GTS's out there for sale. Methinks this Viper has not had an easy life.
TowDawg
Chattanooga, TN
You can't tell for sure form the pics, but it certainly does look like it was in some kind of accident and repaired. I put some notes in the pic to show what I'm talking about. It could be coincidence, and the angle of the pics, but I would tell the seller that I wanted a specialist to look at it in person at the seller's expense. Then you'll see how confident he is of his prestine condition. Tell him if it passes inspection, you will reimburse the the cost of the inspection. If not, he's out the cost of the inspection.
With a possible issue like this, I wouldn't want to spend the money to fly out and see it in person without a qualified inspection first.
Hoosier Daddy
upstate, NY
Agree, looks like passenger rear had some type of repair done to it. Shop never repainted the repair area and has now rusted.
georgethedog
Near Peoria, IL
On the second engine bay picture... Is it normal for the air duct on the hood to be painted on the underside? I don't have my Gen 2 anymore, but I thought that was just all black?
vancouver-gts
Vancouver BC
Something's not right... Silver with blue stipes would not result in a solid blue around the exhauts tips - you'd see some silver down the middle... Give me a few and I'll upload a picture of my old 98 silver / blue GTS.
Hmmm... Uploaded picture but tells me it's an "invalid link" when I try and get its properties to paste in here...
Still... Car in the picture isn't a factory stripe car
here's the picture of my 99 with original paint.Can't be seen in this picture but the blue goes across below the tips not over it.Got another picture where I can clearly see the blue but can't link here only URL's would show.
So the OP's picture looks legit to me.
vancouver-gts
Vancouver BC
I'm too lazy to remove the cover off my car in the garage but I'm almost 100% it's painted the same on the underhood on my car.
Jeebs
Ontario
Well im not sure if its mudd or bad welds but i wouldn't count bad welds out. The place that use to make/weld the Viper frames is a factory 15 minutes from my house. I used to work their about 10 years ago. Scretchy to say the least. All though they did quality control, there was some stuff that got buy. Im being nice when i say some!!!!
BUT i still bought my Viper, but i did do my own very extensive inspection. :D
Camfab
SoCal
I can tell you for a fact, that Vipers have HORRIBLE welds. They look like they were and I'm sure were welded by a bunch of drunks. Corvettes on the other hand have the finest welding that I've seen on a production car. (Actually the Ford GT has excellent welding as well) I hope I've offended the Weldor's that worked in that facillity, because they deserved to be fired. Better yet shut the whole facillity down, it's places like this with non caring useless people that have made North America the laughing stock of Automobile manufacturing. Jeebs tell me you weren't a weldor, and hopefully that place went under.
JKGiant
