Wheel fitment question GenII to GenIII
DMan
Maryland
Anyone know if iForged rims from a GENII would fit my 03 GENIII? Thnx.
MTGTS
Orlando, Fl
I don't believe the rears will clear your brakes unless they already had a bbk on their gen 2
D
DMan
Maryland
Oh, yea giving the size might help, duh. 18x10, 19x13 - front/rear. They're iForged 3 piece.
Omaha NE.
Unless they were built for a Gen3 they will not. The Gen2 wheels have a different offset. The Gen3 wheel will fit a Gen2 but not the other way around.
treesnake
St.L
If you go to DAVES BIG BRAKES OLD website, (see below) he has a template you can print, cut out and place in the wheel to see if 18 in. wheels will fit over SRT calipers.
Gen 2 guys use this template when upgrading gen 2 brakes to SRT calipers to check wheel clearance.
This is from DBB's website;
Caliper to wheel clearance
"A" is the caliper to wheel clearance needed 1.4" min
"C" is 7.75" arc for SRT Calipers
"C" is 6.75" arc for 13" Rotors &Calipers
chimazo
Clarksburg, MD
They should fit fine as long as it isn't a set with the 5" rear lip. You might need to relocate the parking brake, though.
