Wheel Hop
HPATTERN
Smyrna TN
I have an 06 viper. Under hard acceleration there is a lot of wheel hop. Anytime the tires spin. Is this just part of it?
black mamba1
CT
Switch to PS2's and get rid of the stock run craps. That will solve your problem totally.
MikeR
Hard accell or hard shifting will still get wheel hop even with PS2's. But PS2's make a big improvement. A combo of Motons and PS2's basically eliminate wheel hop but its still there.
Hamrhead
eastern, Pa
I switched to PS2's and it did decrease my wheel hop problem.
I still get some hop, but not as harsh as with RunFlats.
MikeR
Dont take this the wrong way but learn how to drive it.
Dont take this wrong, but if YOU are not getting wheel hop out of the stock set-up, your not driving it hard enough. Maybe you use the skip shift feature??
JACKED DADDY
COLTS NECK, NEW JERSEY
My 06 coupe does the same thing. It also looks weak to the on lookers. I am wondering if we should launch a little harder. I light up the C5 convertible right through third. Smelly tire burning, smokey sideway action. Man I dont have the heart to do that to the viper. If you experiment let me know.
ILLSMOQ
SAN JOSE, CA
HAHAHAHAH!! Seriously, anyone who says they don't get wheel hop without doing major modifications is not driving the thing hard enough!:rolleyes:
With the stock suspension it's like tire basket ball.
RAYSIR
Salem, OR
I think we all like to burn the tires once in awhile. I changed fron stock to all new PS2s 4 months ago. It made a little difference but still it would hop bad enough that I would think it could tear out a rear end mount. Man, The guy that comes up with a traction bar set up for a Viper is going to be one Rich ****. It has to be the A arms twisting back and forth??:dunno: :dunno:
Dave Moore
Bridgewater, NJ
I have done the motons, the engine and transmission mounts, the quaife rear diff. and the ps2's. It still happens once in a while...I just give it more gas and hold on:omg: :D :D :drive:
Andrew/USPWR
W. Palm Beach
The 345x19 are the widest production tire put on a car. That’s a lot of rubber surface area trying to grip the road.
My GTS was worse.
dave6666
A lot of good info here, as I've wondered about the wheel hop in my '01 GTS. So I guess I DO drive it hard enough...
Does anyone know if wheel hop eventually ends up breaking anything, or causing premature wear on any particular part(s)?
ILLSMOQ
SAN JOSE, CA
Riding out the wheel hop is one of the worst thing you can do to the drive line. It's like a jack hammer on everything.
MikeR
Yeah... he is right, But It usually happens if Im racing somone or showing off, so I just ride it out.:D If something breaks.... F**k it, I'll buy a new one. :lmao:
(Tht last line is more a inside joke for ILLSMOQ)
RAYSIR
Salem, OR
The problem has nothing to do with the tires or with the rear end bushing or transmission bushings. It is the A arms twisting back and forth with no lock or support. Think of how traction bars work on a car with springs or coil overs in the rear. To get rid of wheel hop on a Mustang with upper and lower track bars and coil overs you put in poly bushings. On a vehicle with a 4 link more rigid set up there is no hop. Need to design a traction bar running from the lower A arm to the frame that can swivel yet keep the A arm from twisting for and aft. Are there any stiffer than stock A arm bushings out there aftermarket ?That would help. Have to get rid of the twist upper to lower.
Omaha NE.
There are plenty of independant rear suspension cars out there that do not have hop issues. The problem can be greatly reduced with a few mods if not eliminated. Granted they are pretty pricey solutions but they will improve the Viper in alot of other areas also at the same time.
dave6666
Twisting the control arms certainly sounds BAD! Poly bushings seems only like it adds more support, but does it actually reduce or eliminate the forces that are bending the arms?
dave6666
Care to list these $$$ mods? I saved a few $$$ after the car was bought for stuff like this.
Omaha NE.
Non run flat tires
Moton suspension with the correct Eibach springs
Proper alignment settings
quaife differential
I think a lower gear ratio helps also but just my opinion
Racelogic traction control will not let the wheels spin as much and will recover smoother
Hope this helps
MikeR
Again, the PS2's make a huge difference, and then adding Motons after, basically eliminated wheel hop. I rarely if at all hop anymore. It was real annoying whn car was stock.
Yetsterday some guys were yellin at a light to do a burnout, so light turned green and I dropped clutch and it smoked and spun tires nice and smoothe for a loooong ways, on run craps i would have been hopping all over the place.
dave6666
I have Pilot Sports - the directional ones. Everyone is saying PS2's versus run flats. How much difference in regards to wheel hop will getting rid of my Pilot Sports and putting on PS2's make?
ulllose
Brunswick, Ohio
I Have Wheel Hop And Hate It!!!!!!!!!!!!!!! Just Thought I Would Comment That I Have It And Still Have No Figured Out How To Get Rid Of It Completely......
ViperTony
For what its worth, I had a lot of wheel hop until I adjusted my shocks. It turns out the Koni's were each set at a different setting from the factory. The settings ranged from 0 - 6 half-turns. Tator advised to me set them at 2.5 and most of the hop is gone.
ulllose
Brunswick, Ohio
Nothing,,,,,,lol I was just hopeing that It would just go away.....
I have been watching wheel-hop threads for the past 3 years and still sounds like the best way is to switch out to motons and that is not completely 100%.
So yes i'm the type that ******* about the President and doesn't vote....lol J/K
No members online now.
Razorwire
