Where and what power steering puller tool to buy?
supra360
Ontario, Canada
Hello Gents,
I am going to replace my power steering pulley, does any one know what power steering puller works the best and where is the cheapest to get it?
Nick
Have you asked about a rental at AutoZone?
Ron said this:
"Matco MST93 pulley remover & installer kit
worked perfectly. "Easy method" leaving the pump on. Took all of 45 minutes for
both the pump and the bracket but the radiator was out for repair so there was
some extra room. The pulley came off and went back
on perfectly without breakage. Used Dave's Big Brake / JonB version. Looks nice
but Sean's w/ spacer looks more OEM"
Above is last post in this thread:
http://forums.viperclub.org/threads...wer-steering-pulley?highlight=steering+pulley
Grisoman
Are you getting the bracket too? If so, you'll be pulling the pump from the car anyway and don't really need the puller (just cut the old pulley/hub off the pump shaft). I tried the puller route and it did not budge the pulley. Maybe your luck will be better.
supra360
Ontario, Canada
Yes, I purchase the bracket too. I pick up a puller kit today from princess auto (Canada) for $15 half off.
Thanks for the input guys!
Nick
