"where's the oil ?"
tacodan
Had oil&filter change by dealer,replaced oil sensor(leaking).Dealer had to replace 10 qts.oil,not 8 as called for.Last service replaced 9 qts.Manual calls for 8.Dipstick shows o.k.Is everything "hunky-dorey" '94,11000mi.thanks,tacodan
speedracervr4
Lancaster, PA
What year? They changed to a larger oil pan in 2000. It also depends on if all the oil was removed from the oil cooler and if they prefilled the filter.
What manual do you have that calls for 8 qts? My 94 service manaul calls for 10 under fluid capacities in the first section of the book.
xeng yang
