Who has good aluminum foot pedals
Quantico, VA
I would like to but some replacment pedals for my GTS, when looking around I found some (all lot) for import cars are about $35-45.The ones for vipers are $150 whats the deal, its only a pedal, the same ones?
Happy Thanksgiving to All
ACR Joe
Newtown, PA
Jay is right, ZAF has a beautiful set. I chose Snake Oyl for purely ascetic reasons (I prefered countersunk drain/vent holes over raised dots).
If you do choose Snake Oyl, do not use the brackets supplied for the accelerator pedal as they interfere with the operation of the pedal. Cut and glue the screw heads into the countersunk holes to give it the right look. Again, this only applies to the accelerator pedal. The brackets work fine for the clutch and brake pedals.
Good luck ........
ACR Joe
Newtown, PA
I forgot to add, the accelerator pedal (cover) should be affixed using two sided adhesive foam tape. Also the Snake Oyl set is ~ $70. Sorry, business travel is taking its toll.
Happy Thanksgiving
redphazer
