Who has put headers on their car?
Omaha NE.
Unfortunately the weather for most of our customers has been less then ideal for driving or getting to a dyno. Our original beta car is still here but we have not had any time to do anything with it sorry. We also hope to have some figures in the near future for you.
Camfab
SoCal
Are they really two inches long, or is that the outer wall of a dual wall header design. Anyone cut these open to view the cross section?
Omaha NE.
I'm sure there are tubes in there, but they are very short compared to the Belangers.
Jack B
NE Ohio
There are no tubes, what you see is what you got. It does not seem to make sense. Nice comparison; were G4 oem headers the same?
Omaha NE.
The Gen4 and Gen5 manifolds are the same, nothing changed. There are tubes under the encapsulating shield, they are floating tubes that are built to expand and contract with heat so they won't crack like some of the Gen3 exhaust did. Still they are very short compared to the Belangers.
Jack B
NE Ohio
Mark:
I looked inside, there is an inner tube, but, after 2" it meets a horizontal tube/runner. Is the reason for the double wall a heat shield affect? Is the exhaust gasket on the G5 the same as the G1 and G2 ?
SnakeBitten
I could be wrong but looks like the engine is "choked" to 640hp with those factory headers. Could mean some real big gains with a proper h/e/i and tune combination as BBG post is indicating.
DingDong
Any rattling (against other parts of the car) or clearance problems with these new headers?
Simms
Pittsburgh, PA
I will be doing a back to back G5 header test in 2 weeks. We did install a set of ARH headers and high flow cats on a 2013, car runs great, we will be testing that car as well.
I will also be testing a G5 with our new ported heads and Corsa exhaust, no headers. I will post up the results.
This will be interesting to see!
Does anyone know if Belanger plans on doing an exhaust to go with their headers for the Gen V?
DingDong
Goodness! I haven't talked to him in ages! I need to call him!!!
Is he on this site??
DingDong
I was asking about Lou G. I haven't talked to him in years and was just curious if he still peruses this site.
MbnViper
Mark on the TA Belanger/corsa instalation did you use the factory cats or hf ? also I heard Belanger do full exhaust is is louder than Belanger/Corsa setup and any drone ?thanks
Omaha NE.
We used Belanger HF cats. I can't comment on the Belanger cat back, but from past experience would assume it is louder and deeper.
MbnViper
Thanks for the reply Mark.
Hopefully someone install the full exhaust and upload some videos.
labtec
Maryland
Mark on the TA Belanger/corsa instalation did you use the factory cats or hf ? also is the Belanger full exhaust louder than Belanger/Corsa setup and any drone ?
thanks
Lou at Belanger is the man! He walked me through everything before my purchase of the full system. My friend and I installed the complete system on my 04...no problems. Yes it is loud (in a good way), sort of like Armageddon when you start it in a parking garage…hehe. There is also drone at certain speeds. Basically the drone is noticeable in each gear at a certain speed, for example the drone in second gear is at 20mph, in third it is at 30, 4th =40, etc. If you want to scare women and small children you leave it in the drone “zone”, if not just shift out to another gear. In sixth gear at 60-ish it will also have some drone…so you just have to drive faster to make it go away.
DingDong
I'd be worried bout putting these on without CATS!!! It's gonna throw a code and go into limp mode big time after a little bit of driving without the cats....
Omaha NE.
I'd be worried bout putting these on without CATS!!! It's gonna throw a code and go into limp mode big time after a little bit of driving without the cars....
The Belanger come with California spec Cats and the test car has almost 4000 trouble free miles.
Bobpantax
Miami
Hi Mark. Any dyno testing results yet? Stock vs with the whole Belanger set up?
VIPER GTSR 91
Spring, Texas
I just had the Belanger headers and high flo cats plus the Belanger cat back system installed on my ACR and it was WELL worth it. Awesome increase in performance and much louder which is what I wanted. The best part too is NO cel even without the Mopar PCM. Had it professionally installed though by a Viper tech.
