Purdue_Boiler_Viper
Starting my winter project. Going to powder coat all 4 calipers. I think R&J does this. Anyone have any other recommendations?
2001 GTS Race Yellow
Starting my winter project. Going to powder coat all 4 calipers. I think R&D does this. Anyone have any other recommendations?
We have powdercoating services as well. Additional services such as photographic film application is right around the corner, which would allow you to put patterns on various types on parts. Sorry though, no exchange services through us. You will get your own parts back.
I have received powdercoated non-ABS rear calipers that were not disassembled for the coating process. There are plastic ball bearing cages inside, as well as the rubber piston seals, an o-ring on the threaded rod (the part you screw the piston down on), an o-ring out the back for the brake lever... Most times this seems to work, but I have seen some of the rubbers show a re-molded look where they were partially melted, but apparently worked OK. At some point the elevated temperature will cause serious problems that won't be apparent until you install and test the brakes.
I think coaters do this because it is complicated and time-consuming to disassemble and reassemble the non-ABS rear caliper. Ask your powdercoat supplier what they do first.
R&J did mine a few years ago and i am still very pleased.
Are they body-matched, or did you go with black or another color? I have a red RT/10 and if I'm going to have the calipers painted red, I'd like them to be close enough to the body color so that they don't look out of place.
Those look gorgeous!
Did you do the parts exchange, or were those yours? Either way, how long did you have to wait?
My valve covers are starting to flake/peel, so I may just have the calipers and rotors done at the same time since the car will be offline anyway.
