Windshield Cowl help
Xhlr8n
are gen-1 and gen-2 windshield cowls interchangeable?
can i use a gen-2 windshield cowl on a gen-1?
thanks for the help
Tom F&L GoR
Wappingers Falls
Part numbers for 92-93, 94-95, 96, and 97-up are different. (i.e. four different part numbers.) You'll have to find someone that tried it.
dave6666
Pretty sure they are as I have one of each.
The Gen 1 is a heavier material than the Gen 2 and also the gen 1 is shaped differently at the wiper shaft hole area. But other than that I think they will mount up to each other.
GTSDave
United Kingdom
I have a Carbon Fibre Cowl which had previously been on a 2000 GTS on my GenI, fits fine... Whether they would be different was not something I had thought about previously... I can only assume as this fits, that you shouldn't have a problem.
Tom F&L GoR
Wappingers Falls
A further weight savings for my Gen 1?!
Matt Houston
Houston,Texas USA
The bubbling paint usually occurs in ther rivet areas. My question is...what is the rivet "riveted" to? Is it holding the insulation material?
xeng yang
