TAPROOT
I have a question for you????
I have always stayed away from products containing harsh material and or products containing "fillers". I have used everything under the sun as most if not all of you.
Question:I have only been using Z-1,Z-2,Z-6. I had just recently ordered Z-5. I understand that Z-5 is basically a "filler". That sort of bothers me a little.If you use a filler does it ware out of the "filled swirls" after a number of washes?Does it "build up"?
I know these are questions that I probably should ask a chemist or Zaino Bros themselves but I figured I would ask some of you concidering all the Zaino users (distributers) on this board.
Thanks-
Ivan.
Thanks-
Ivan.
