96 GTS: Heater/AC: Low Vent Flow Velocity: Possible causes?
Tom and Vipers
Jeannette, PA 15644
I'm in PA and will be fixing car in NV so just trying to some homework.
  • Blower motor sounds like it is running properly
  • Proper vents active for Heat and AC but flow is very low
  • No sound of "rushing air" in high speed
If I had to guess:
  • Something restricting the blower inlet
  • Blower cage fan is slipping on shaft
Regarding the carbon fiber hood:
  • Hood installed with no cutout for heater intake "shorkel." I think they left the donut rubber gasket off to get some inlet. I suspect driven at 20-40k miles like this.
  • I put the hole through the hood maybe 5 years ago and never got around to putting the screen over it. Car is in the desert and spends 50 weeks a year locked up in an airplane hanger. I doubt that critters built a nest because no debris shoots out the vents when I turn the blower on.
Any suggestions will be greatly appreciated.
Tom and Vipers
Tom and Vipers
Jeannette, PA 15644
Anyone? My FSM's are with the car in NV and I'd like to get some idea what I'm up against.
EXAMPLE: "You have to pull the dash most likely," would mean I'm not going to fix it.
Looks like MoparPartsGiant shows parts manual pics... from what I can see, there are 2 vacuum actuators.
QUESTION: Do the duct flappers ever break off of their shaft? Late 60's GM AC cars did this all the time. From the outside, everything is working but a lame broken off flap screws the pooch.
Tom and Vipers
Tom and Vipers
Jeannette, PA 15644
Drove car home successfully using AC for almost 3000 miles - the continued use seemed to "free up" "stiffness" in the heater duct box. Still, hope to disassemble to get the most out of system.
ALSO replacing the compressor hose O-rings appear to have eliminated the system slow leak (knock on wood.)
xeng yang
