97 GTS radiator fan
98viperGTS
South Carolina
I was wondering what year did they put a bigger fan on the Viper? Is it easy to replace the older style fan with the larger one? I have noticed that my 97 does not cool as well as the 98 that I had. It reminds me of my 96. I just want to make sure that I never have an overheating problem, not that I think I have one now. Other easy cooling tips?
banton
Chicagoland
I believe it is the 99-02 fan module that was larger and is centered vs. the offset version on our 97's.
hemibeep
Tampa FL
I believe there are some mounting bolt location changes, but I am not sure as I also added an aftermarket rad. Plug connector was a plug in.
Cal Cobra
Brentwood, CA
I put the larger fan in my 96 and I had to change the plug on the harness, and I think just add or remove one or two mounting bolts. It was pretty straight forward.
Cal
Mpcc
