AB's wires + retaining clips
apun
AB's wires are too thick for the plastic retaining clips...is it OK to just zip tie them up instead?
Thanks,
Alex
A
apun
I tried pretty hard and the only way they can go in is if I start using pliers to crimp them in there. Even then, I could probably only get 2 wires per clip.
Alex
Knight Viper
Harford county MD
They are tight but you can still fit all 5 into one, if you want to make it a little easier, ream the hole just a bit but not too much were you weaken the retainer
ruckdr
Renton, WA USA
They fit just fine on mine.
A
apun
So I did some measurements with my caliper:
plastic clip on my 99 GTS: 0.280-0.312" (varied within one clip)
stock wires: 0.250-0.310" (depends on how hard I pinched the wires with my calipers)
AB wires: 0.310-0.340" (ditto)
What I ended up doing was drilling them out a little larger. I broke one so then I started using a file to open them up a little bit. Works OK now.
Thanks,
Alex
ruckdr
Renton, WA USA
Apun,
The blue clamp holder, to the left, in the picture is aftermarket; the black wire holder on the right is the stock wire holder.
Later,
A
apun
Apun,
Later,
Hi Don,
Yeah, my stock wire holder does not look like the black one in that picture. On mine, I have to stick a little screwdriver to unhook it and then it folds open so I can put 2 wires on one side and 3 wires on the other side. The black one in the picture looks like you can just push the wires into the holder.
Thanks,
Alex
A
apun
Here's a fuzzy picture:
Bigger picture attached.
Alex
A
apun
Whew, thanks OKViper, I thought I was alone. Maybe the 99's had a different clip?
The p/n for the clip is 5245 237AB.
Attached is a diagram.
Alex
Qdog
