Are paxton novi 2000 pullies interchangeable?
97snk
Will a pulley off of a mustang with novi 2000 work on the viper system?
Is the stock paxton pulley 6 or 8 rib?
Does anyone know the belt part # to run with the 2.75 pulley with the 8 rib pulley?
97snk
The pulleys are "somewhat" interchangeable. It depends on the offset. A spacer can assist the offset.
The stock pulley is 8 rib. The stock pulley size is a 3.75"
The stock belt is a gates or equivalent: K080485 -GATES.
The Gates belt sizes are here: http://www.gates.com/oreilly/PDFs/SizeListings.pdf
Hope this helps!
Thanks Doug...I can't seem to understand what belt would go with the 2.75 pulley from that link, could someone give me the exact belt number...
SKY1960
