onerareviper
Hello Viperholics,
1.) I bought the clutch kit from the EBAY many people use. I am positive it has the correct pressure plate, clutch disk, throw out bearing, and pilot bearing. Now I've been told the alignment tool that comes with the kit is not correct. Although, it lines up with the splines in the center of the replacement clutch perfectly. Do I have the correct alignment tool? In other words, if the tool lines up with the splines, could it still be incorrect? I have yet to install the unit.
2.) In the manual, it states you HAVE TO replace the slave cylinder when replacing the throw-out bearing. Is this necessary? More than likely I have a bad throw-out bearing.
Thanks in advance.
Thanks in advance.
