Clutch Issue with 2001 GTS
Purdue_Boiler_Viper
Indy
Was pulling the car out of the garage a few days ago. Pushed in clutch, started car, put shifter in reverse and let out on clutch. Normal let out on clutch, pulled out of garage slowly, but then pushed in on clutch and nothing happened. Still headed right for my other car! Yanked it out of gear.
By pushing the clutch pedal clear to floor, the clutch does slightly disengage so I could pull the car back into the garage.
Any suggestions on where to start to diagnose / fix the clutch?
Thanks in advance.
GRN_MTN_VPR
Burlington, VT
Agreed with Barry,
Check fluid level first, then master cylinder, then slave cylinder. Happened to me once in my FD RX7, except I was on the road driving.
Odds are it is the slave cylinder....though on a couple of occasions, I have seen slave and master cylinder go out on 2001-02 Vipers whose clutch fluid was not regularly changed.
P
Purdue_Boiler_Viper
Indy
Good to hear from you again. Would you recommend anyone local to do the work?
Yes, first class experienced guy.
As I got to thinking about your car, I had a question and a possible answer not covered above.
Call me when you like...317-402-9013
tophermecier
Red Lion, PA
These throw-out/slave clutch cylinders are sensitive on these Tremec setups (I've had issues on my Z06 T56). As Steve mentioned, the fluid not being taken care of can lead to wear and tear and the slave is a common failure point. These cylinders tend to dirty up system fluid more quickly and the abrasiveness of dirty fluid will do damage. I highly recommend annual or bi-annual flushing/bleeding. I typically do it the lazy way and drain and fill the reservoir through the year to keep fresh fluid through the system. Takes a few minutes with a good syringe. If you drain the reservoir and refill, pump the clutch a bunch of times and check it, you'll see how dirty it gets as it cycles in with older fluid. I do this until it stops getting dirty, plus some. Wrong? Maybe, but the Vette scene has been doing this for years with many happy users, because proper bleeding under the car can be a pain without a bleed line installed.
Hope it all works out! Glad you didn't hit anything!
analogmike
My '01 GTS had (has) similar issues. The clutch would go to the floor, it was dripping by the trans so I knew it was the slave cylinder. I would fill the reservoir and it would work ok but occasionally lose the pedal. Driving with the foot resting on the clutch pedal a bit would get the pedal back.
I had the slave replaced, but it still gets soft sometimes though no fluid leaks. I bled it really well so I don't think it's air. Maybe I need a new M/C too... time to bring it to Tator's.
P
Purdue_Boiler_Viper
Indy
Just circling back to let people know what the fix was. There was some fluid underneath the car, right below where the ***** cylinder is. The reservoir was empty, so sure enough the ***** cylinder had begun to leak. I got a replacement throw out / ***** cylinder from Roe and that fixed it right up good as new. Thanks Steve for the mechanic recommendation.
GTSGTO
Delaware
You should also block master. Taken in context that's a more offending word.
BlackWidow
Admin
Staff member
Administrator
Az
I looked up the word s l a v e (*****) in the profanity list and could not find it, so maybe I'm looking up the wrong word.
{edit}However, I do see that ***** is being blocked, I will enquire because that is odd
slave
Corrected, I would guess that it is part of some global **** hurt list from some social chronically offended group. We are not and it is part of the Mechanical culture.
Sorry for the trouble
xeng yang
