Bolt
There has been many posts about heat problems with these engines. While I have my heads off I found this coolent passage hole. It is only 1/8. Should it be larger to allow the coolent to flow or is this just a hole to allow the air to get out of the block when filling the coolent? What would happein if I drill it out to 1/4 inch? I always had high RPM heat build up. Could this be the problem or is this a factory error of not drilling it out larger? Anyone have any viler blocks laying around which you can take a picture of this area?
