Cpe Turbo Installed
1Need4Speed
Houston, Texas, USA
It's been a while since I posted the CPE Turbo install on my 2001 Sapphire GTS with stock motor. I ran into some personal issues in my life and had to put the car on hold for a bit...
Anyway, here's the update::eater:
I took some time off and drove up to Chicago to meet up with Paolo to pick up the car a couple of weeks ago. He had called and said he completed the install for the turbo side mount system for my car.
When I got to Paolo's shop the car was up on the lift so that he could show me the system from under the car for starters. I will have to say that I was nothing but IMPRESSED...The install was precise, clean and the attention to detail was perfect! :2tu: From the upgraded fuel system with the larger lines, using braided lines for the **** install, upgraded half shafts, Spec 3 Plus clutch upgrade, Eibach springs, side mount intercoolers and the piping install for the turbo system...WOW!
We dropped the car down from the lift and inspected the intake tubes, custom fuel rails, crank case breather, turbo manifolds and turbo install. The welds were unbelievable on the turbo manifolds and intake piping that Paolo designed.
I decided to do the side exit exhaust system utilizing actual Gen 1 sill covers. Paolo hand built the 4 inch stainless exhaust and custom fabricated a 5 inch polished tip.
The install of the system definately exceeded my expectations! :2tu:
We decided to go for a spin at that point (who wouldn't!)...
I started the car and must say was blown away from the tone of the exhaust and the spool of turbo's! We took the car out onto some back roads that he directed me. The Eibach springs were a perfect ride for the car and made the car handle in with a race car ride...The clutch was smooth and almost had a stock feel to it.
We started out with duing 4th gear pulls to see how the car reacted and to keep the clutch from over working since it needed a break-in period. This is like nothing I experienced! As the turbo's spooled the power was unbelievable! The tunnel vision and pressure from the pulls will need some time to get use to:D
The side exhaust was a thrill and sounded almost evil under throttle and boost. :omg: We made pull after pull for 3-4 hours and with the AEM plugged into the laptop to data log each pull. There were no issues with overheating. The boost was set at 10 pounds and the system was very rich to keep from detonating.
There is about another 100 plus horsepower wants we get the car tuned with the **** when I bring it back to Houston. We can then get it on the dyno can do some more timing increases and back off of the fuel a bit since the Methanol will be turned on and see what kinda power this thing makes.
Now back in Houston, I've been driving around in this crazy heat for 1-2 hours at a time with no issues what so ever accept refilling at the gas station;) The spooling of the turbo's around town is SOMETHIN! The wine of the turbo's cruising around and then under boost..DAM!:headbang:
I'll be meeting with Jimmy Voorhee's this weekend to tune the car. I'll post some dyno pulls and looking forward to some addtional power with the **** and great numbers.
I will have to say this about my experience with CPE Turbo. Other than the delay on my end...the experience with Paolo and his enthusiasm for the project and passion for these Vipers has been wonderful...GREAT guy and this dude know's this car hands down! He has built a great kit for our cars and this is just the beginning power level for my project. It will be some time before I decide to take it to another power level with this system.
If you have some kind of mod you want to do to your car and have some extra cash...you gotta get one of these dam things! I can't stop sneaking into the garage to take glimpses of my new beast and know that my car has twins now and lots of joy rides to take:2tu:
Bruce
Check out these pics at Paolo's place...beautiful...enjoy!
FATHERFORD
Texas
Good to see more of these kits on the road. Pretty sure that's the setup I'm going with next year.
IEATVETS
Cottage Grove, Wis.
Paolo is a great guy and will treat you right everytime.
Did you happen to change the pistons or do you still have the casties in there?
Post dyno #'s when you can.
1Need4Speed
Houston, Texas, USA
Stock bottom end...that's why I went with the **** system.
I want to enjoy the power first then go from there. It will take soNext years project which will be to pull the motor and go through it.
I should have some dyno numbers in the next couple of weeks to post for you guys.
Bruce
1Need4Speed
Houston, Texas, USA
Looks great Bruce - you will have to take me for a spin sometime..... :)
What part of Houston are you in? It says NW Houston. I'm close to the Champions area so let me know and we can meet up.
There is a car show by Gleannloch Farms every Saturday around 6:30-9ish. I should be there this weekend if you want to meet there.
hou99gts
Rosharon, TX
I met you at the last RSI meet before they closed. My name is Eric and I had the 99 Silver GTS with Black iForged wheels. I live 2 minutes from RSI in LOEN.
Unfortunately I am busy this Saturday night, so I'm gonna have to take a rain check.
1Need4Speed
Houston, Texas, USA
Hey Eric how's it going? I remember the silver GTS and the wheels...nice setup and attention getter.
I'll keep you posted when me and the other Viper boys hit the town. Should be soon:2tu:
Take care
Bruce
Casey
Valparaiso, IN.
Congrats. You have a gorgeous GTS---CPE TT style!!
140 will become the starting point in a short while, then you'll be cruising at that speed. Enjoy and be safe!
JG01
Another CPE Twin Turbo on the road. Bruce your car is so nice and the installation looks magnificent. Congratulations to all involved, now punish that beast every chance you get.
Don’t worry about the cast pistons either, with the tune you have in your car you can hammer on it all you want.
1Need4Speed
Houston, Texas, USA
Thanks a bunch...
I would have to say that the power is addicting so I'm trying to be cool with it.:drive:
JGK95
Chicago
Bruce,
Head over to CPETurbos.com & Nav. to the Customers page. You might see a Sapphire GTS that you recognize!
:D
Jay K.
SKY1960
