crack in fog light lens
SBMIANO
Discovered a crack in driver fog light lens on my 09 vert. Can I just replace the lens or do I have to change the whole assembly. How do I do that? Should I change out the bulb with something better? Appreciate the feed back.
SBMIANO
Is that the lens the whole assembly? Is it hard to put on? thanks
gb66gth
Big-D
If you can take off your front wheel and turn a screwdriver you can do it in 5 minutes. I did.
Dom426h
DE
The gen2 ones are glass and 220bucks. When mine cracked from a rock on the freeway or something I simply slapped a pre-cut yellow laminX tint on it to hide the crack.
I like the look of yellow tinted fogs...
potterb4
