Daytime Running Lights Question
Looki
Hey All
I need to add daytime running lights to a 2000 Acr that I have bought. I decided to spend the dollars and order the OEM module vs the Crappy Tire one that you have to splice into your wiring harness.
The dealer says the OEM one is plug and play, but can't tell me where the plug is?
Does anyone one know??
Looki
Paul S Lacey
UK
From memory the realy goes on the chassis rail which side I am not sure.
Sorry I cant help more
Dave149
Ontario, Canada
It goes on the passenger side of the aluminum brace behind the radiator. The plug should be hanging around there somewhere.
L
Looki
Thanks Dave you where exactly right :2tu:
Looki
RTTTTed
You can also use any Dodge (neon) module that will fit! That should save you $500 in case you have a bad shop do the changeover.
Otherwise join the VCA, use a 4" piece of wire and see the pics and instructions in the Illustrated Upgrades (members only)
Ted
tbone96
