Ever lock yourself In the car?
okloneranger
It happened to me today. I've had a battery tender plus connected under the hood. Green light on, disconnect tender, start up, back out of garage and shut off so I can help get Christmas decorations out. That done, get back in to go for a ride, strap in, shut door, insert key, turn key and nothing. Well, better get out to open hood and take a look. Door won't open. Turn key again, nothing, turn off and hear click-click-click which keeps going till key turned to on position, then it stops. Turn key to any other position and hear click-click-click. There is an emergency exit lever on each door that will alow you to exit. I don't remember what I did that finally stopped the clicking, figure the battery has gone south, however, pushed it back into garage and hooked battery tender back up. Three hours later-battery tender plus is showing green light-but-doors still won't open. I don't understand. Can anyone explain to me what is going on? Battery is probably original to car, it is Mopar-no gripe here concerning battery life. I just don't know what the clicking was or why the tender is showing green when it appears the battery is dead. :dunno:
RapidTransit
Concord,Ca
8 years from the battery is asking alot, probably dead...had the same thing happen with my Harley, say's good(green)but won't turn it over..go figure..New battery fixed it.:dunno:
O
okloneranger
When we pushed it back into the garage we did it by turning the tires by hand. I wasn't sure if there was anyplace on the rear of the car that was a no-no for applying that much pushing force. Anyone knowledgeable there? How about pushing it backwards from the front, where on earth do you push there?:dunno:
O
okloneranger
Oh, by the way, I left the battery tender plus attatched (not sure why)and today it has the green light lit. Battery is still DOA.
N
Nobody
Guest
Battery is sulfated. they do that over time, or if you let them go completely dead in a much much shorter time...either way as others have said it is toast.hence giving false voltage readings and offgassing a bunch of corrosive gases and highly flammable hydrogen gas when you try to charge it...time to replace...oh yeah don't make any spark's ..I had one blow up trying to charge....very ugly
O
okloneranger
Thanks,charger disconnected, knew the battery was toast-didn't consider gases. I thought about keeping it on it till new battery replacement-guess that is a non issue. What about safe places on the Viper body to push from both front and rear?
motor602
Silver Spring, MD
ive never had any pushing issues on my RT, especially when my battery died. Had four valet guys pushing me down the street with no issues. GTS im not 100% but Im sure your ok.
Ratical2
San Jose, CA
The is voltage and then there is voltage under load.
Wow, 8 years! The battery has given up the ghost and you have definitely gotten your moneys worth out of it.
hemihead
Commerce Township, MI
Especially giving up the gost in the driveway, that would never happen to me.
In the spirit of the season, give thanks.
O
okloneranger
Not to beat a dead horse (replaceing battery), but I'm still curious as to what the "clicking" sound was when the battery quit. Anyone know what that was?:dunno: Thanks for the help and info!:2tu:
N
Nobody
Guest
Starter solenoid (it's a relay) edit: opps reread your post key was in off postion.....still sounds like a relay tho
O
okloneranger
Thanks; At least if only a relay is messed up the repair expense will be relatively light. Hard to say why it kept fireing, but it didn't go for long so hopefully a battery will be all that's needed. Your imput is appreciated.
Warfang
California, East Bay
I hear the side view mirrors provide good grip when pushing. :rolaugh::rolaugh:
Seriously though, it's a good question. My guess is if you can get your windows down (if you have windows) I would push by the A-Pillar either way. Any other suggestions?
O
okloneranger
Thanks, Snake. Such a simple and logical thing to do.(I should have thought of it):2tu:
Skunk Works
Probably had a dead cell in it, or the cold cranking amps were shot. I don't have a Viper yet, but in my truck it died on me. Jumped it off, took it to the parts store, they hooked up a battery reader and it said it was fine... changed a setting on his diagnostic tool and it showed a dead cell.
Battery was charged, but would not allow it to kick over. Sounds like the battery tender was saying it was charged, and it could have been, but may be an issue similar to what I had.
Just a shot. Battery tender may be ok, but the battery was still bad.
Phun70
Urbandale, Iowa
Relays were clicking trying to energize. Due to low volts/amps all they could do was give a halfhearted click. Hope this helps.
webironmongery
