exhaust weight-searched found nothing
randall
Overland Park,Ks.
getting ready to install my corsa cat back,feels heavy.
how does the weight compare to stock?my corsa is 2 1/2 inch.
R
randall
Overland Park,Ks.
just called corsa and they had know idea what the weight of there system was,seems odd that an aftermarket company wouln't know this information
ViperGTS
After installing the 3" corsa two weeks ago I GUESS it is twice the weight of the stock exhaust system...any measurements so far?
R
randall
Overland Park,Ks.
so any acceleration gained do to increased h.p. would be lost,so the only advantage is sound.unless the added weight over the rears increases traction?
Russ M
LA, California
WOW.
This means that adding a corsa exhaust to your car actualy makes it slower!!!
Since it weighs more and adds no power, that is the only possible result.
jcaspar1
Sacramento, CA
"WOW.
Since it weighs more and adds no power, that is the only possible result."
It's like adding a subwoofer. More weight but sounds better. The RT cats save weight and make more power....
LTHL VPR
Just checked my stock of Corsas, and the 3" systems are 113lb., including the boxes they come in. Your 2.5" system would obviously weigh less, but I'm not sure by how much. (We use the 3" systems exclusively.)
ViperGTS
>>>Just checked my stock of Corsas, and the 3" systems are 113lb., including the boxes they come in.<<<
>>>I weighed my stock exaust: 50 lbs without cats<<<
Seems to me like twice the weight, or?
But, sound matters!
jcaspar1
Sacramento, CA
3" stainless is pretty heavy. I bet a 2" system would be a lot lighter!
Actually, going to side pipes would probably give the best of both worlds (lighter and 3")
R
randall
Overland Park,Ks.
put the corsa on this weekend.
corsa cat-back=66 lb.s
factory cat-back= 52 lb.s
14 lb.s diff. for the 2 1/2 inch.
corsa said it maybe adds 10 hp,i hope this makes up for the extra weight.don't think the sound is much improved though,kinda sounds like a 6-****** w/ glass-packs.
jp
Umea, Sweden.
I have 3" sidepipes with Race Bullet mufflers, the weight is about 8 lbs each...and the sound is!!!
The weight excludes Belanger Headers.
/JP
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jcaspar1:
<HR></BLOCKQUOTE>
onerareviper
Pittsburgh, PA, USA
randall,
What cats are you using? I have the 2.5 Corsa on my '98 GTS with Sean Roe's Oval High-Flow Cats, and it screams!!! From my experimentation, I've found cats play a major role in the sound produced.
Later
R
randall
Overland Park,Ks.
onerareviper,
i still have stock cats,my concern is the second o2 sensors.will this make the check eng. light come on?
artman
GA, USA
FYI: I had a new set of 3" Borlas shipped and UPS weighed the box in at 69lbs...........
kodiakleather
