Fluids for 01
Skeeter Blanton
Valdosta, Ga.
It has been 5 years since I have had a Gen. 2 and would be interested in knowing what fluids and oil filter might be recommended.....My car (01 Roe SC, 4400 mi. )will be delivered today....Thanks very much....:drive:
08 GTS Blu/silver stripe coupe
2010 ZR1
2007 Z06
1993 Callaway Aero/Lingenfelter 383
OEM Fliuds for 2001 Viper:
Motor oil...Mobil 1 10 W-30 (best price is 5 qt. jugs at Wal-Mart)...read the label carefully as there are several different 10W-30's made by Mobil 1 that are sold there....AND...you MIGHT wish to consider switching to a different oil since you are running a Roe...and, presumably, still live in a Southern climate.
MOPAR Oil Filter ( NOW Viper Specific 1992 thru 2006) 05037836AA.
MOPAR "Power Steering Fluid Fluid" 04883077.
MOPAR "Antifreeze/Coolant 3 Year Formula" 04267020AB.
MOPAR "Brake & Clutch Fluid DOT 4" 04549625AC.
MOPAR "Synthetic Gear & Axle Lubricant SAE 75W-140" 04874469...for differential.
MOPAR " Limited Slip Additive Friction Modifier" 04318060AB...for differential.
MOPAR "Synthetic Manual Transmission Lubricant SAE 75W-85" ( also known as "Castrol Syntorq LT 75W/85").
R134-a for A/C refill.
Mopar ''spray white lube lithium grease'' 04318066AB for door hinges.
Have FUN !!!
GTS Bruce
Orchard Park,NY,USA
You might consider using Mobil 1 or Rotella synthetic turbo diesel oil 5-40. Per our oil guru much higher in anti wear additives and detergent. Per him all diesel oils superior to gas oils due to a much stouter additive package. I switched to the mobil 1 5-40 but next time will use rotella since its 1/2 the price. GTS Bruce
userSRTbro_
