Fueling an RT10......Problems?
Steve Miehe
Cincinnati, OH. USA
There was a post recently where some folks indicated problems getting fuel into their RT10 - fuel handle kept clicking off as if the tank was full but there was plenty of room for more. My '01 has this problem and am looking for a fix. Has anyone figured out a solution for this problem??
Fort Lauderdale, Florida.
Unfortunately, you have a bad (or stuck) rollover valve. The valve is stuck in the closed position on the fuel fill entry. Your lucky, the 01 has a valve that can be removed for service but must be facilitated from inside the tank. If you own a GTS it's much easier to service - you must remove the fuel module. If you own an RT/10, it's easier to change your religion - you must remove the tank. You can try to pour some type of cleaning agent (marvel mystery oil) or slide a small fuel line down the fuel fill hose to break the valve free. Usually when this type of problem occurs, it's because the car sat for some period of time or was a leftover from the dealer.
Good luck I hope this helps,
Doug
slaughterj
Once in a rare while (2 or 3 times in 12K+ miles), mine will stop early when filling up, about 2 gallons shy of full, not the standard "tank is full" cutoff. Is this your problem, or just any point at filling?
David Jenkins
South Orange County, CA.USA
There's a vent hose on some of the late R/T's that kinks. You have to remove the rt. wheel and loosen the inner fender well for access. Should be covered under the warranty. Or like Doug said, rollover is stuck.dj
Steve Miehe
Cincinnati, OH. USA
SlaughterJ:
The handle clicks off every tenth of a gallon or so. After putting about 3 gallons of fuel in the car, I'm frustrated to where I just head home.
slaughterj
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Steve Miehe:
SlaughterJ:
<HR></BLOCKQUOTE>
Definitely different than my rare experience, doesn't sound like too many possibilities given the responses above. Good luck with it!
Tom F&L GoR
Wappingers Falls
My '94 fills fine when the engine is off; constantly clicks off when the engine is running. Perhaps the return line foams the fuel near the filler pipe and sends a false foam signal (FFS)? Maybe I invented a new term...
Tom F&L GoR
Wappingers Falls
Vip-RT10 has a good comment about static.
The static electricity problem is when re-entering or exiting the vehicle and your body brings a static charge to the refueling location. Reaching for the nozzle (or anywhere the vapors are) creates the spark that may ignite the fuel vapors.
I don't like to leave the nozzle unattended. I hold onto the nozzle, which keeps me grounded (the hose is conductive) and the concrete should also be conductive (special concrete slabs.) Other types of surfaces are likely obsolete due to enviromental ground contamination issues.
The static electricity-explosion hazard isn't generated because the engine is running. In fact, some can start by reaching for the cap and removing it. Engine-off warnings are aimed at back-fires (pre-catalyst car days) and now more emissions related (charcoal cannister vents to gas tank, pressure is monitored or used by some systems.) In any event, Dodge has made it self-correcting, since I can't refuel with a running engine anyway.
static fire reports
jwolf
Vincennes IN
I know this is and old thread, But I am just getting around to replying with pictures.
My RT has the same problem the only way I have found to get gas in it is to have the handle upside down to the way you would normally use it.
Most of the time I can get it to run at the slowest notch but sometimes I still have to hold it.
CEJ
Raleigh, NC
I'll try that next time. Mine also can be hard to fill at times. Thanks jwolf.
Yeah, on my 67 Dart I have to fill it on the slowest click or sometimes I have to manually hold it even slower than that. I put in an aftermarket tank with a built in pump and between the vent line being small and losing a baffle that runs down the fill neck it just doesn't exhaust air as fast and the tank fills. I've had it burp a fair amount of gas out several times when filling, not the most fun to clean up and dangerous at times.
dmerkle
USA
My 2000 RT/10 never seems to cooperate at the pump, regardless of how much is in the tank, always clicks off after 2-3 seconds of filling.
Neither rotating the handle or using the lowest fill setting have helped for me.
This weekend though, I was able to pump in 9 gallons without one click off.
Put the nozzle in but put my finger under the contact point between the pump handle and the body.
Then pushed up on the handle, as in trying to move my hand toward the center of the trunk.
scottmarston
Meridian, Idaho
Don't shove the nozzle in all the way and it won't click...mine fills up just fine. Have to be aware of the gallons you're putting in or you will fill it to the brim. If you listen closely for a change in pitch, you can tell when the tank is almost full.
Grisoman
Woah is that hose touching your car?? Don't tell me you use the two-bucket car wash method as well.
Grisoman
No issues herewith fill ps. Fuel gauge nose dive after the half hash mark is another story.
VYPR BYT 94
Green, OH
It's like when you use a funnel to fill a mower. When you fill it so fast the air flow gets choked off then it backs up to the top of the funnel, right?
Well the safety equipment detects this and trips off. Obviously every pump will be different.
By turning it upside down you literally "flatten" out or squash the round pattern of the gas, thereby allowing more room for air. That is why it works.
Mohed2003
