gen 1 dash removal(light switch help)
brukowski85
long island, ny
ok i have one last part and im stuck..can get past the light switch ive looking and search forums also anyone have any interactions or pics
ILLKing
Upper Marlboro, Maryland
I had to cut mines off. I kept knicking away at the back of it until I was able to pull it off. I goes back on, just that its missing a fair amount of material on the back of it. There is supposedly a little hole in it that you are supposed to stick a needle in and release a clip that grips the metal shaft. Best of luck
SNKEBIT
western wisc.
Pull the light knob out like you turned on headlights. Reach behind and find the small button on top, iirc, of the electrical part of switch, depress button and pull the knob and shaft the rest of the way out. If you haven't unhooked the battery, your lights will be on until you disconnect the switch base from the connector.
SNKEBIT
western wisc.
That is a gen 2 switch. Bottom of knob you turn lights on with has a little hole in bottom, stick real small screwdriver, etc. in there to release clip.
rlamorte
