SmokinViperGTS
After running about 15 runs on the Vegas auto-x course this spring, stopping for lunch, and then hitting the road course for a couple of 20 minute sessions, my differential overheated to the point that I was blowing 140 weight past the seals and all over the underside of my car. Made for a stimulating blue cloud following me around the track, until I got black flagged. Thought it was some other problem, and got that fixed, but continued to have the problem on my next drive (easy highway cruise), until I finally found the problem. That's when I was told that the Gen I's and II's have a weak diff that commonly overheats on the track. It you don't monitor it (how?) and let it cool, you blow a seal and get to see your favorite mechanic again.
But I was also told that Dodge has a kit cooler specifically for this, and found it in the Mopar Street Essentials catalog - part #P5007010. It requires me to either drill and tap my diff case for the fluid lines, or replace some portion of the case with a newer Mopar part (that I haven't found yet) that has the ports built-in.
So, now I'm wondering if anyone else is using this kit, or something else, to solve this problem? What sort of experience are you having with your solution? What did the kit cost - I've heard it's quite expensive? Who carries it?
Thanks,
Steve
DIFFERENTIAL COOLER SYSTEM
Designed to keep your differential cool under
race conditions.
• Recommended for use on 1996–02
Vipers used at racetrack events
• Temperature switch automatically
activates pump and fan at elevated
temperatures
• Production housing requires drilling
and tapping for fittings
• Differential disassembly recommended
• Mopar Performance differential housing P5007441 and
differential assemblies P5007401, P5007402, and P5007403 are
pre-drilled and tapped
Kit includes:
• Electric pump
• Air-to-oil heat exchanger
• Electric fan
• Required hoses and fittings
• Wiring harness with factory connectors — no splicing
• Temperature switch and relay
• Templates and instructions on compact discs included
P5007010 1996–02 RT/10 and GTS Differential Cooler System
Thanks,
Steve
race conditions.
temperatures
Kit includes:
• Electric pump
• Electric fan
