Not sure of the current draw but I did swap that in my 95 Gen 1, the wiring harness connector is/was different so if you can get the connector from one of the parts guys you can wire it for both fans and make it easier to swap back should you ever opt to do so. I swapped to an aluminum radiator at the same time and added a power steering cooler, that really helped on warm days at the race track.
