Gen II fog lights
AJ02
Azle Tx.
Were the foglights for a Gen II used in any other car? I'm about to pull the front fascia to get it repaired from the blown out truck tire I hit and both my foglight lenses are cracked. Good time to take care of them, I just have a hard time justifying $400 for two little light assys. I know the Gen III lights are half the price, but it looks like the mounting brkts are different?
ViperTony
One of my foglights has a cracked cover. Looking for something reasonable myself. I dont believe the lens is sold seperately. Not a big deal but eventually I want to fix the foglight.
A
AJ02
Azle Tx.
So far, the cheapest I have found new ones is $173.00 each. That ***** as the Gen III ones are only $95.00 each.
Jance GTS
Oklahoma City, Oklahoma
Brackets and mounting locations are the same for the Gen 3's. You will have to cut and splice your harness to make them work since they are a different bulb, but well worth the trouble for the upgrade!!!
Indy
Vancouver
If you don't use your fog lights too often, you could also get rid of them altogether and put some brake cooling ducts there instead. Probably the same price, if not a lot cheaper if you fab your own system.
Jeebs
Ontario
Im also following this because I'd like to put fogs in my acr and im not spending $400 on two fog lights that are 3.5" big. There has to be a cross part number.
The vw thing sounds interesting.
A
AJ02
Azle Tx.
They might still be available over there, but I've been all over the net and called the local VW/Audi dealer and found that the lights were for a 1982-1990 VW Polo and are discontinued. Audi dealer couldn't find the part #s. I can't find them on the Hella website either. I guess I'll just go for the Gen III lights and splice the harness.
potterb4
