are you hearing the soleniod in the bottom of the door clicking when you pull the handle? if so, I would be betting that the actuator rod from the door soleniod came loose some how. Everything is working fine, except the soleniod is not connected to the door lock any longer. the emergency exit SHOULD be connected independantly. check it out...
