HELP!! 1st problem with 02 FE
Cape Coral, FL
sound like the wire to the soleniod in the door came loose/broke... are you SURE the relay is clicking? or are you hearing the switch in the handle click??? it is LOUD. does the little light on the lock switch light up when the passenger side is lit?
Cape Coral, FL
are you hearing the soleniod in the bottom of the door clicking when you pull the handle? if so, I would be betting that the actuator rod from the door soleniod came loose some how. Everything is working fine, except the soleniod is not connected to the door lock any longer. the emergency exit SHOULD be connected independantly. check it out...
ctrengine
