genXgts
Hey Gang,
Pulled my 97 GTS out of hibernation finally for the first time Sat night and encountered a severe metal on metal rubbing noise coming from what I have deduced down to the rear diff.
I do recall some grinding when returning from the dealership on the frame recall, I had them change the fluid in the diff at that time. Thought I'd investigate in the spring, and here I am.
Took a look inside the diff today and the amount of fluid looks fine, no leaks to speak of. Everything else looks good, nothing rubbing or wear marks anywhere. If the dealer did not add the friction modifier would the noise be a result? (was charged for the modifier on the bill)
Straight line no noise, say 30, 40 degrees off center in light turns nothing, take a 90 degree corner (not near cranked 100%) and the noise comes on, seems to have the same pitch and frequency, does not lighten or worsen based on steering angle, and then stops when straight or near straight.
Anyone offer and troubleshooting on this, the dealer is 200 miles away.....
thanks for any help,
