ZDigital1
Special Thanks to RPM Transmissions and IPS Motorsports!
Here's some of the new mods to this custom build:
*Upgraded transmission to TR6060 and 2.66 ratios with .80 changed 5th gear
*RPS Triple Carbon Clutch (1200 ft/lb capable)
*DSS Carbon Fiber Drive Shaft
*DSS 1400hp CV Axles
*MGW Shifter
*Quaife Differential fully Micropolished
*FIC 1150 CC Fuel Injectors & RSI Fuel Rails
*Paxton Novi 2500
*Tial 50mm Blow Off Valve
*AEM Stand Alone Fuel Injection System and 3.5 Bar Map Sensor
*Nitto Invo Tires
*Doug Levin Intercooler Kit
*Stop Tech Slotted Rotors (all 4)
*Snow **** Stage 3 Kit w/ Custom Aluminum Tank hidden under trunk
*Custom Quick Disconnect Fuel Drain (Race to Pump)
*One Off Custom Water Pump and Crank Pullys
*Roe Racing Red Silicon Coolant Hose Set
Unbelievable power! All grins and smiles here!!
*MGW Shifter
*Paxton Novi 2500
*Nitto Invo Tires
