I've seen ppl heat one pipe, not at the join (so as not to heat both), but further up. I've also seen special tools, 'pullers', etc. I'm sure someone else here will steer you in the right direction
My experience - after loosening the clamp itself, had to to tap the clamp in several places to break it loose from the two flanges. It seemed that it was the clamp that was stuck to the pipe flanges, once loose the pipes separated with no hassle.
Remove the nut and bolt completley then carefully spread the 'outer' clamp a bit. Then with a blade screwdriver, pry lightly in different areas until the inner clamp releases from the exhaust pipe/manifold connection. Just slide the whole thing onto either the pipe or the manifold and thats it. It can be completley removed safely and properly only after the pipe is removed from the manifold/header. Hope that helps. I have been there COUNTLESS times.....
