red98GTS
I posted this some time ago, so for those of you who know this already, I'm sorry about the repeat performance here, but some of you have asked me what the deal is on this. This applies not only to your Viper, but to any other car you may have with the glued-on rear view to the windshield. So, hopefully, this will help somebody eventually. You have two choices here. One, you can take it to any auto glass shop and they will glue it back on for you and charge you a few bucks to do it. If you have done this, and the mirror still falls off once in a while, go to your second option: buy a "one-shot" kit and do it yourself.
These little kits are available at almost any auto parts store and you want to buy the one made by Loctite specifically for the rear view mirror. NOTHING ELSE. No epoxies, no two-part glues, no Superglue, nothing. OK. Here's how to do it RIGHT. Mark on the outside.....yes, the outside of the windshield with a magic marker or grease pencil, directly over the spot where the old bracket fell off. You can usually see some of the old adhesive left. Mark it with a dot right there. This will be your reference point when you go to glue the bracket back on. Otherwise, you will just be guessing. Take a brand new and only brand new single edge razor blade and use it to remove any leftover adhesive from the inside of the windshield until it is completely gone and clean. An old, dull blade can scratch. Now, remove the bracket from the mirror with a screwdriver. Don't attempt to do this with the bracket attached to the mirror! The kit will contain two things: a primer and a glue. Take the primer and apply it LIBERALLY to the area where the bracket will be glued. DO NOT WIPE IT OFF. Leave it to dry for a bit. The secret is not wiping off the primer. Do the same to the bracket surface after you have cleaned it just like the windshield. If you use the single edge razor to clean it, be careful. Those things remove fingerprints instantly. At this point, be SURE you have the windshield side of the bracket up, and prime the surface just like you did the windshield and DO NOT WIPE IT OFF. Let it dry for a minute or two. That's long enough.
Now, you can apply a couple of drops of the glue to the bracket. More than that is worse than less. Immediately press the bracket to the windshield using the mark you made as your guide. Just moderate pressure is fine, and hold it there for two full minutes if it is relatively warm where you are doing the work. Release the bracket and immediately wipe any glue from around the bracket with a paper towel, going around the bracket in a circular motion so as not to smear the excess glue all over the dern thing. Wait about ten or fifteen minutes, and put the mirror back on and tighten the screw. You don't need to wait till the next day, wait until after dinner, wait until you "think" it's on.....just ten or fifteen minutes is plenty. That's it. If you followed these instructions, it should be a done deal for a long time. 99 out of 100 never need to be re-glued after this, although some brackets are not perfectly flat and sometimes a new bracket helps a troublesome re-glue repeat. Oh, one last thing.....DO NOT use a grinder or a wire wheel to clean the bracket!!!! Once scratched or gouged, the ability of the glue to hold the bracket is diminished. I know that doesn't make sense, but...........just don't. Hope this hasn't bored you to tears.....somehow I can hear grown men openly weeping now........pete the ex glass guy
