I can´t find the green "program" wire
Tomas
Åland Islands (Baltic Sea Hawaii), FINLAND
I can´t find the green \"program\" wire
Hello Everyone.
I can´t find the green program wire for the remote programmming. Can someone mark on this pics about where to look.
regards
Tomas
hemibeep
Tampa FL
Re: I can´t find the green
If it was on a GENII it would be above the gas pedal. I thought somewhere I read that on GEN I the wire is on or near PCM....sorry I can't help
SNKEBIT
western wisc.
It looks like it's stuck in that bundle on the right side there. Right above the carpet. Looks like it's going up into the air duct. At least, I think it's that one.
NOTV8
Re: I can´t find the green \"program\" wire
Hello Everyone.
regards
Tomas
Tom,
If you look on the top side of the EEM there are some numbering on it. You'll need to look on number 13 which is the green wire. Do not disconnect the green wire you will need to get a solid 18-22 gauge wire and push it in inside the connector within the green wire. And then ground the other end. Give your self a good 2-3 feet of wire for ease of grounding. I can't see on the picture if you removed the bungee cord out of the EEM. Let me know how you make out. Email me if you still have some question.
