I need a power steering pulley or hub measurement
Tomas
Åland Islands (Baltic Sea Hawaii), FINLAND
Hi everyone
Yesterday I mount the hub on the power steering pump axle, I mount the hub so close as possible to the housing, but still the hub are not flush to the axle. Can someone please take a measurement for me so I know if I have the hub on right place on the axle.
thanks
rgds
Tomas
or this measurement are also interesting, from bottom of pumphousing to top of pulley
Paul S Lacey
UK
We fitted a 96 in a 94 car and with the 96 bracket the pulley was out of line. So we used the original braket and all was OK.
From memory we used the original pump and took the crate motor on off when fitted with an early pump the later bracket was fatter.
You should really email Dave at Dave'#s Big Brakes he is the master of the pulley and brackets
Dave's Big Brakes
San Diego Ca USA
Hey Tomas,
I didn't ask, which car are you trying to install on? The billet pulley is for 96-02 with oem mounting bracket(96 RT/10 are different)
I measured the hub & pump, it's 103.76mm from the back of the pump to the front of the hub. It's about 47.3mm like in the first picture above that you have in this post.
Dave
