Injector clips.
J DAWG
MS
When installing the new injector clips is it possible to cross up the wires?
Are they specific to a certain post on the injector or not?
John
Bill B
Plantation, Fl. 33323
Do you mean put the wire on the wrong injector or put the plug on upside down? You can put it on the wrong injector. You can't fit the wire on up side down.
J
J DAWG
MS
I was referring to putting the wrong wire in the wrong hole in the clip. There are 2 wires and 2 holes in the clip. I realize the clip can only fit 1 way, but was wondering if the wires could be crossed - say put the green wire in the left hole when it should be in the right hole.
I will just pay close attention when removing the old clips and do them one at a time.
KWIK96
LA and Oz
I have had a look at the cct diag of my 96RT, and one side(wire) of the injector is always hot (when the ignition is on) and the other side(wire) handles the earth/ground connection to complete the cct and work the injector. This earth/ground comes from the PCM.
I would not advise mixing these wires. This is a DC cct.
Hope this helps.
Would be interested to know how you ended up needing to change these, as you are really messing with the wiring loom here and it's a bit out of the norm?
:usa:
ruckdr
Renton, WA USA
The 10 injector wires are numbered 1 - 10. You probably can't see the numbers attached to the wires under the intake manifold.
J
J DAWG
MS
Hope this helps.
:usa:
the injector clips have been the culprit for many people having intermittent breakups thruout the rpm range. Those clips are also included with the Roe s/c to try and combat any missing that may occur from a poor injector connection.
I am just trying to rule out these as my misfire culprit and they are really not to hard to change once I got into it.
Jack B
NE Ohio
There is no polarity issue, therefore, either wire make-up will work. I would suggest having a few extra connectors just incase you error when crimping
J
J DAWG
MS
thankfully Sean did send a few extra metal connectors. It took me about 3 to get the hang of it, but the hard part was pushing the dang clip on the injector. These things are definetly secure.
Mike Adams
guelph, Ontario, Canada
When you do I personally solder every one of them to make sure a good connection. You don't have a Roe blower do you ? You will not be able to pull the connectors through the intake when you are done it you have stock intake
J
J DAWG
MS
I see what you are saying Mike. I am SOL if I want to take the stock intake off since the clips won't fall thru the rails.
tbone96
