Is a Vec 1 harmful to the motor in anyway?
V 10 MAFIA
Has anyone experienced any problems with there car relating to the Vec 1 after installation? Burning Valves? Computer Problems?
PhoenixGTS
Phoenix Arizona
It totally depends on what YOU do with it. You could hurt the engine if you used the VECI to make it too lean or have too much timing.
FE 065
MI
I don't think the VEC1 does timing.. But you could make your engine too rich or lean for sure with it.
Call Sean Roe, he can tell you all about it :)
PRVT JET
streamwood, il usa
It does do timing, on the high setting, between -14/-20 the timing is advanced about 6-7 degrees. read the instructions, they explain everything.
isaac
Cerevo
