Magnecor Vs AB Wires
Izover4u
Chicago, IL
When it comes down to it-- is one really better than the other in performance? Or is it just color preferece?
plumcrazy
ALL OVER
ive owned both and soon as they are both in your hands, you wil see why i will always have AB's wires on my car
Cape Coral, FL
We hardly use anything but QualityWires anymore. Not that I have anything against the others... but they just arent the same, and the customer can see that immediately.
Kala
Ojai, CA
I've had AB's wires... for about 6K miles... No problems!
[media]http://loverotts.com/bluwires1.jpg[/media]
Warfang
California, East Bay
But aside from appearance, one does not perform better than the other...:eater:
You mean has anyone hooked both units up to test machine to get accurate readings? Not that I know of. Has anyone installed one and taken a couple laps.... then installed the other and took a few more to see if there's a difference? Not that I know of.
You would think if there was a significant difference, someone would have noticed by now. IF there was a difference in performance specifically... I'd bet my paycheck it wouldn't be anything worthy of mentioning on either side. What's with the fascination? Are you a Magnacore plant? :smirk:
Or is Magnacore THAT much cheaper? If it is... you'll get what you pay for. You've asked members for their opinion, and they gave it to you. You can support a Viper brother that has better quality wires from initial inspection and preforms just was well as any, and to top it off, he stands by his products like no other. Or... you can do what you want to.
I
Izover4u
Chicago, IL
guess my fascination as you put it is that I need to purchase a new set of wire b/c my stock wires failed... Was just looking if there was really any performance difference between the two. Im sure he does stand by his product but what if he decides to give up his hobby of making spark plug wires? Then what? Ordered Magnecor wires and spark plugs from Jon B... Great Guy!!:2tu:
Thanks for your input
Warfang
God bless America. You have choices. Just don't pretend you're here for opinions when you've already made up your mind... without any explanation as to why. Are the savings THAT much if any? Seems odd to me that you know nothing of a guy that everyone speaks highly of and try to trash his business by calling it a "hobby", and suggesting he might fold at any moment.
What's the point of Magnacor being in business forever if they don't stand behind their product today?
VicTxV10
Victoria, TX
Will the AB wires fit the stock wire holders on the engine. I want to get a set of red ones. I have an 06.
I
Izover4u
Chicago, IL
Seems odd to me why you are accusing me of trashing his business when I am not... I am sure his product and service are great however, from what I heard he's a huge viper enthusiast and does it on the side... Does he not? What's your problem?:crazy2: After talking to Jon B I decided to go with the Magnecor wires plain and simple... is that ok with you? btw: giving up or changing a hobby does not mean he is going to fold:rolleyes:
AB if it is not a hobby or a side gig, I am sorry if i offended you in any way as I did not intend to do so:)
Warfang
I'm just going by what you said. You said it was a hobby and speculated you'd be left out to dry if he "changed his hobby." To quote you..."Im sure he does stand by his product but what if he decides to give up his hobby of making spark plug wires? Then what?"
"Change his hobby"...if the hobby is a business... is the same as folding.
Doesn't matter either way. You bought a product you're happy with. Congrats. Hope it doesn't break on you, because Magnacor will screw you.
V
Venomiss
Guest
You can send ab a PM here or try below. Adam actually does quite a bit on all kinds of cars and has done illustrated upgrades.
home For your Viper!
1992 Black Lamborghini Diablo
1992 Red Ferrari 512 TR
[email protected]
LiquoRT/10
Got a set of quality wires from AB and he threw in a set of plugs for free. Can't beat that.
Thanks AB.
Racer Robbie
Guilford, CT-USA
I also have been using a set of Magnecor wires that I bought form Jon, Parts Rack, and they have over 10,000 mikes on them with zero failures. I believe they are every bit as good as Livewires, or AB's wires when used in the proper application. I believe Magnecor wires are designed to be used as an upgrade to the stock factory OEM wires in a viper that does not have headers. When uses with the spark plug metal factory shields one should have zero issues. If you have headers I would always use AB's wires as they are assembled to handle the extra heat of the header.
One will have to order a set of 13 spark plug wire separators from Dan Lessor, Viper Specialties, as all the above mentioned wires are bigger in diameter than the stock wires. While they can be crammed into the 13 stock separators I would not recommend it. You can see them here at: https://www.viperspecialtyperformance.com/catalog/product_info.php?cPath=73_35&products_id=149&osCsid=d55799a1fde1b3fc45603a3a3f82d6e5
I
Izover4u
Chicago, IL
Thanks:2tu:
dave6666
I used the free Viper pen I got with the purchase of my Magnecor wires, to address the shipping label on the box they were sent back to Magnecor with. After they melted of course.
Moral of story: Save the pen.
BTW, no disrespect to Robbie's comments above on the wire holders, but on my '01 the Magnecor wires did fit the stock holders well.
ViperTony
I got AB's wires 2.5 years ago and they've been great. They fit the stock wire looms...I'm not certain why some folks think this is the case. The wires and customer service from AB are top notch. Like Tator, AB knows how to treat his customers. :2tu:
Qualitywires.com
Louisville, KY
Thanks all for the support! Wow! That's the reason why I give back to the Viper community. I am one of the sponsors for the Bradenton Viper Shootout event coming up and also support friends such as Chuck "The Wizard" Tator with the sales of my wires in his fight with Chrysler. I will back up my wires with no BS attached. I even take it on the chin when the wires are damaged and know it's not my fault because I understand the customer experience is #1 plus your car is your baby. (So far no one has tried to take advantage of me so I have been able to continue to do this). My wires do come with a lifetime warranty against defects.
Will I go out of business? I could just like anyone else, but I do everything in cash so I can sleep at night. ;) So far I invest all monies back into the company either by sponsorships or helping others. I am doing this to demonstrate that I value the loyalty of the Viper community. What movie was it that they said "Build it and they will come"? So I am taking that approach.
As far as other wires, yes there are many choices out there and only customers can testify on my products. I am sure other wires are nice and so on, but I personally think I take more of a personal approach and pride in what I do. I have business internationally now and the word is spreading on qualitywires.com! I even have people who disliked me come back and say great things about my wires.
But like I said before, it's your car and you pick what you think is best for it and hopefully I can earn your future and repeat business! Thanks again all for the support! We are growing and looking to do more with the future support!
By the way, I would say that most of the most visible Viper tuners use my wires and come back for more.
Qualitywires.com
Louisville, KY
Here's some pictures. Also do a search..many threads on my wires also.
viperbilliam
Richland, WA
According to AB's website, he only makes them for Gen I/II. His message about a temporary website gives us Gen III's hope.
No members online now.
Razorwire
