Misfire question
ACR Larry
RPV CA USA
I just recieved my car back from an Arrow engine rebuild. It ran great for about 250 miles, then the engine light came on. When I tested it with the OBDII, the error showed up as a "random misfire". Any ideas? :confused:
Cape Coral, FL
hmm...off the top of my head, things that could cause a random misfire would be:
-bad plug wires (multiple) which are arcing to each other
-bad coil pack
-bad wiring to a coil pack
-VERY bad gas
-fuel system issue (pump, regulator, clogged filter...this option is less likely. would usually show up as a "lean bank 1 & 2)
Vic
I get "multiple mis-fires" sometimes.
Though I had it beat when I put new plugs in, but the fault came back. Maybe I'll look into the wires.
rlamorte
