Mopar Ecu
Viperoctane
I know that they are discontinued, so I am wondering where can I find a new or used one ??? Also I heard that mopar is coming out with a new one, anybody know when ?? I have a check engine light from the headers so I want to get rid of the light. Thanks
lleone
Rochester, NY
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Todd Richmond:
Other PCMs might also fix your problem. I sold someone my Henessey Stage I and he said it worked for him.
<HR></BLOCKQUOTE>
That would be to me. It has worked fine with my 2000. Even disabled the skip shift.
RedGTS
Tennessee
You don't necessarily need a performance ECU--a stock '99 version should work as well, which you should be able to order from any dealer. It was '00 when the ECU was programmed to check the temperature on the front O2 sensor after startup.
Ronnie
"If It Fits On Or In a VIPER: P A R T S R A C K !
---MoPar ECU
---1999 ECU
---Headers that WONT throw lites in the first place.
Or any other Viper item. THANKS!
GTS Bruce
Orchard Park,NY,USA
Didn't know that Jon.If I had known that in the first place I would have bought one of those from you too(99 ecm).I have the Ox. sensor located in a primary tube and if there are any problems you will be hearing from me to order one of those older ecu too Bruce
V
Viperoctane
Thanx guys for the replies.
Mark, I cant find anybody here in the boston area to do that for me. I hardly found someone to install the headers in the first place.
JonB, You will be hearing from me soon
