MOPAR Performance ECU - What was it intended for?
DrumrBoy
GA
The MOPAR Performance ECU is useful for a number of things for which it was not really intended. What was it primarily designed to do, does anyone know?
Cape Coral, FL
Very similar to a basic SCT flash. Slight fuel/timing changes, skip shift delete, and emissions monitors turned off.
Nsane1
Dallas, TX US
I just did mine in my 08 makes a huge difference in throttle response (that I think was fixed in later years).
D
DrumrBoy
GA
Thanks. I've always wondered about that. I've been aware of the last part but didn't know about the fuel/timing changes. Mine doesn't seem to run very well with it in.....but that's probably because the ECU "tune" is for a stock motor and mine is a heads/cam car that likely has different needs.
Cape Coral, FL
Correct.
In all honesty, there is basically zero point to running a Moper Performance ECU these days with SCT and HP Tuners available.
Also, some of the MPP ECUs end up in other years they were not intended for, and the result is often running slower processor hardware in a car that could technically be running the newer version ECU on SCT.
D
DrumrBoy
GA
Correct.
Agreed, I only use it once a year ;-)
D
DrumrBoy
GA
Thanks, I didn't know that.....now I do and If the MP ECU ever quits working the SCT Is my next purchase.
JKGiant
